Kenwood or Clarion
josmuck
21. März 2006
Hi i have the Kenwood KDCPS909 head unit
http://www.vannin.com/area51/kenwood.htm
and realley like the Clarion DXZ938r would there be that much of a diffrence between them without the LZK? do you think that the Clarion will sound that much better? Remember the Kenwood is older but also 1 of the top units when it was sold and hase the 8v balanced out put.
Thanks for any help
Brian
The Clarion 928 / 938 Headunits have a fantastic, clear sound. in addition with the Time Alignment and the parametric EQ you have a powerful tool to adjust the sound in your car to the best.
I will never ever buy a Headunit without Time Alignment, that is THE feature for me. Just hear it!
Tip: When you connect the Line-Outs fpr Front as following:
left side at front-left output
right side at rear-right output
you can use the EQ for left and right seperately, that will improve the stability of the staging when it is measured in with eq. Liberty Instruments 'Praxis' software.
mr woofi du kannst in deutsch schreiben er versteht das aber schreibts nit so gern.:)
mfg didan
Gut denn in Deutsch :)
Das HX-D1 habe ich mir auch schon angeschaut ist aber keineswegs vergleichbar mit dem HX-D2, ist eine ganz einfache Headunit die nix kann.
Addzest ist zwar wirklich Clarion (heißt in Japan so) würde einen Kauf aber keineswegs empfehlen.
Thanks for the answer. i will be looking for a DXZ938R. i have always liked the looks and the quality of this headunit.
Rgds Brian
