Ein klein wenig vom neuen Alpine DSP.....mit Foto
Ein bisschen mehr info:
ALPINE ELECTRONICS’ FACTORY INTEGRATION OPTIONS PROVIDE SYSTEM FLEXIBILITY
Award-Winning Audio Processor Allows for Sound Tuning of Factory or Aftermarket Systems
Although factory sound systems are becoming more complex, it does not mean that customization of these systems is no longer possible. To address this challenge, Alpine Electronics of America, Inc. provides several factory integration solutions, including the new PXA-H800 IMPRINT® audio processor.
IMPRINT Audio Processors
Alpine’s IMPRINT technology is a suite of advanced, automated sound tuning processes. Covering the majority of vehicles, IMPRINT takes the speaker level output from a factory head unit and provides the platform for a complete sound system upgrade. For aftermarket-based systems, IMPRINT takes analog as well as digital inputs and allows for convenient control over certain sound functions and sources through compatible Alpine head units. Alpine amplifiers, speakers and subwoofers can then be connected, for the ultimate high performance, custom-tuned sound system experience.
IMPRINT technology drives the new PXA-H800 OEM or aftermarket sound processor. IMPRINT consists of five technologies:
•ImprintEQ, Alpine’s automatic sound tuning technology -- Using the supplied omni-directional microphone, measurements are taken from various locations in the car. The resulting data is used to automatically correct any in-car acoustical problems and then apply the desired target sound curve.
•AntEQ, which removes the factory head unit equalization, leaving a blank slate for these subsequent steps
•Road EQ, which automatically corrects for external noise in real time
•MediaXpander™ Plus, which improves the playback of compressed media and restores high-frequency audio data
•User Customization, which gives the user the option to customize the sound via manual or automatic settings – Using either the RUX-C800 controller (sold separately) or a PC with the included tuning software, manual, target curve and post process tuning can be made. The user can customize the sound traditionally by hand or automatically tune it to a desired response, while also allowing for full adjustment for fine tuning afterwards.
At this point, RCA signals are used to connect components like Alpine amps, speakers and subwoofers, via high-voltage preamp outputs. Using the 4-volt outputs results in better signal-to-noise ratio and increased output levels to all channels.
The PXA-H800 is a winner of a 2011 CES Innovations Design and Engineering Award in the In-Vehicle Control/OEM Integration category. It uses superior components, including four 24-bit high-performance Digital to Analog Converters (DAC) and a dual 32-bit floating point operation Digital Signal Processor (DSP). It has 4V outputs and a new input architecture that allows for use of the car’s factory radio volume control while maintaining fidelity.
The separate RUX-C800 in-dash controller is required for programming and stand alone use with the PXA-H800 and provides a convenient way to adjust the PXA-H800’s settings from the dash. When used with an Alpine head unit, the RUX-C800 provides control over certain sound functions and sources.
Pricing and Availability
The PXA-H800 will be available in April for $699.95 MAP. The RUX-C800 will also be available in April for $249.95 MAP.
Und..
Alpine’s second IMPRINT audio processor is the PXE-H660. Now available at a lower price of $249.95, the PXE-H660 IMPRINT OEM Audio Processor enables consumers to upgrade their factory systems. Once the PXE-H660 applies the IMPRINT technology to the factory head unit, automatic sound tuning can take place and aftermarket components can be added to the system. The factory volume control can still be used for truly seamless operation, either with the included wireless remote or integrated with a factory steering wheel control adapter (if the vehicle has steering wheel control capability).
The PXE-H660 is available now for $249.95 MAP
Da habe ich ja richtig gut orakelt :hammer: - Denn die 700 US $ werden wohl oder übel bestimmt 750 Euro werden, wenn nicht sogar noch etwas mehr.
Vielleicht sollte ich an die Börse gehen :ugly: :hippi:
Was hat denn das RUX Bedienteil damals gekostet ?
Gut ist, das man das ganze per PC einstellen kann und wenn ich das richtig lese, die Lautstärke auch per original HU regelbar ist.
Wie das ganze dann am Ende wird, da lass ich mich mal überraschen.
Irgendwie bin ich nach wie vor froh, das ich beim Angebot von nem F#1 zugeschlagen habe...
Gruß Christian
das rux war früher auch nicht günstiger glaub ich, hat auch um die 200€ gekostet, wenn der preis am ende auf 599€ für den prozzi und 199€ fürs rux hinausläuft finde ich das ganze realistisch...
Phil
und noch ein bild:
PXA-H800
Seite:
Andere Seite:
RUX-C800
"Auch wenn der PXA an ein Ai-NET HU angeschlossen sind.
Dazu ein paar info von Alpine USA:
Fully Manual Tuning built-in ... a la F#1 Status and H701
Dual Optical Input + Ai-Net Input + Ai-Net Aux
Ai-Net Connection to INA-W910 - Preset, sub Level and Balance/Fader
Tuning is done via the new RUX or the PC Software
6CH Input (RCA or SPK Input - Up to 10V Input) / 8CH Fully Active Output (4V Output)
- In fact, our CES Demo Car is running an 8CH Active 4-way setup w 2x1" TW, 2x5" Mid, 2x8" Front Sub, 4x12" Rear Subs)
Improvements over the H700:
Huge Signal-to-Noise Improvement - 110 Digital / 105 Analog
Increased Channel Separation - 90dB
Significantly More Powerful Manual Tuning
(+/-12dB for all bands vs. 9dB)
10 Band Parametric for Front Rear and Center (vs 5)
5 Band Parametric for Sub (vs 2)
Includes ability for 36dB XO Slopes
-24dB to 0 Level Control (vs -10dB)
Yes, it has ImprintEQ built in, however this is a totally new tuning process compared to the previous Imprint It is significantly more detail in its resolution/measurements, especially in the mid and LF range. This allows us to tune that area with a lot more detail and accuracy. On top of that, you guys will be able to choose from 3 alpine defined target curves, as well as set your own target curves (drag and drop in the PC software) to auto-tune to your tastes. You'll be able to tune to your taste, either by full manual tuning, auto-correction or auto-correction + your own manual turning.
It is designed to work in both OEM and ultra-high end AFT system, with the ability to manually or automatically to satisfy pretty much any tweakophile.
Phil
Bei 700 US$ für den Prozessor und 250$ für den Rux wird sich das ganze am Anfang nie und nimmer bei 599 Euro einpendeln, da die Europreise schon immer höher waren als die $ Preise.
Wie ich schon schrieb, um konkurrenz für MindMap und Bit One zu sein, müsste der Preis so sein, aber für Alpine HU Nutzer die nicht noch ewig auf den MindMap warten wollen, wohl die einzige Alternative wenn man kein extra Bedienteil mag.
Aber was schön zu ist, das sich auf dem Prozessormarkt so langsam aber sicher mal was tut.
Wenn der von anfang an gut läuft, könnte ich mir vorstellen das der ein oder andere vom BitOne rüberwechselt zu Alpine...
Wenn der MindMap dann endlich mal kommt, wird der überhaupt noch AI Net haben ?
Gruß Christian
ich hoffe mal das endlch mal die aktuellen prozzis marktreif werden .
Warte extra noch ab mit dem prozessorkauf weil ich keine lust habe mir in 2 monaten nen anderen zu kaufen ...
Die Infos klingen schon mal net schlecht
was mir irgendwie noch fehlt bei den ganzen Abgaben ist die Schrittweite bei der LZK
hoffe das die kleiner wird als die 0,05ms beim H701
Markus
Lawyer schrieb:
Phil
Ähm, Dollar Kurs 1,3
700/1,3 = 538 € =>599 € wäre denkbar
249/1,3 = 191 € => 199 € wäre denkbar
Damit lägen Sie über den $ Preisen (umgerechnet) aber man wirds sehen und nicht beeinflussen können ;)
Michael
Das ist allein aufgrund von anderen Garantieleistungen so nicht realistisch.
Und als vertrieb hat dann auch noch keiner was verdient....
CLK63DK schrieb:
Yes, it has ImprintEQ built in, (...) On top of that, you guys will be able to choose from 3 alpine defined target curves, as well as set your own target curves (drag and drop in the PC software) to auto-tune to your tastes.
Was diskutiert ihr hier über EQs, wenn ihr DAS habt? ;) Ich bin gespannt.
...zumal man immer bedenken muss: Preise in den USA sind OHNE Steuer (tax), die kommen im Laden dann ja nach Ort, County & Staat drauf. In Deutschland sind die Preise schon inklusive den 19% USt.
Wenn man also umrechnet, dann muss man das auch richtig machen:
538 + 19% = 640 Euro (außerdem kommen da noch ein paar % Zoll drauf, d.h. mind. 670 Euro)
191 + 19% = 227 Euro, hier gilt das gleiche.
Wenns denn endlich mal ordentlich in Verbindung mit nem aktiven System geht mach ich Freudensprünge.
Ja, das bei VOLLAKTIV, und ich werde heiraten.......... :hammer: :ugly: ;)
Mich persönlich hat Imprint bisher noch nie interessiert. Was hab ich davon mehr als von einem EQ oder was kann Imprint, was andere Prozessoren nicht können ?
Gruß Christian
Finde es Klasse das Alpine in diese Richtung weitermacht und wenn alle anderen welche DSPs angekündigt haben auch einhalten und überzeugen könnte es das Jahr der Prozessoren werden.
Gruss Robi der wartet
Imprint ist grundlegend anders!
Imprint ist eine Impulskorrektur. D.h: Imprint entzerrt Reflexionen und ist in der Lage, das Lautsprechersystem zu linearisieren und den Raumeinfluss zu reduzieren/ aufzuheben!
Imprint ist etwas vollkommen anderes, als die übliche Korrektur per DSP. :)
Grüße,
Michael
Wenn dich Imprint bislang nicht interessiert hat, kannst du ja auch gar nicht wissen, was es besser kann.
Sagen wir mal so: Ich finde Imprint ist zum ersten Mal ein selbsteinmessendes System, das wirklich gute Resultate hinkriegt. Selbsteinmessung gabs vorher schon, aber die Ergebnisse war eher mittelmäßig. Beim Imprint ist das Resultat so, dass 95-98% der Bediener damit ein BESSERES Ergebnis hinkriegen als wenn sie die Anlage selbst einstellen... und da gehören auch viele "Klangfuzzis" dazu, denn - um in der Realität zu bleiben: Wieviele Leute geben am Ende eines Anlageneinbaus schon hunderte Euro für das professionelle Einmessen einer Anlage durch einen Profi mit entsprechenem Messequipment aus? Und für alle, die das nicht tun, bringt Imprint eine bessere Lösung als wenn man das Einstellen selbst vornimmt.
(Ärgerlich war bislang nur, dass Imprint eben keine vollaktive Anlage einmessen konnte. Das dürfte mit dem neuen Prozi aber nun hoffentlich erledigt sein.
Viele Grüße
Matze
Ärgerlich ja, aber wenn man undogmatisch an die Sache herangeht, braucht man so oft gar kein aktives System. Insbesondere da Imprint ja auch ein Bisschen mehr macht als nur im Amplitudengang zu zerren ;)
Ansonsten natürlich vollkommene Zustimmung. Darüberhinaus macht Imprint zwar vielleicht nicht mehr aus Gold Platin aber auf jeden Fall Sch*** zu einem sehr goldig glänzendem Metall :)
